need a new transmission, what to buy?
Re: need a new transmission, what to buy?
wow this is great i need axles and nobody has helped me out in like a month with the answer. do i need mx axles or bp axles and how do i mod them?
- Limegreen mx-3
its not wow
its wow ur the smart person on here that has no clue what ur doing u have got urself into a lil project u have no idea what ur doing i tried to explain it to u and u keep stating what axles u need mx-3 or bp.
common sense says the MX-3 axles will not fit in the bp trans i guess u know better rite.
i took the time to put something together to help ur smart azz out do i get a thanks for that being that u have being rude on this post last couple of times. since no one else seems to help u out but me..
i didn't put much step by step i don't think i need to for u some one else can be more informative than me so here the link and next time post this in the transmission forum
there u go i hope u understand now because if u don't im going to wish i can knock some god damn sense into u. u not modifying a axles ur modifying a bp half shaft for gods sake,.
guy get a brain and some common sense.
sorry for being rude guys and u mazdamx3sohc u just seem like a lost cause.
well all have lives beside being on this forum 24/7 mazdamx3sohc next time do ur research before u do anything else
http://www.mx-3.com/phpBB3/viewtopic.ph ... 93#p442193" onclick="window.open(this.href);return false;
well i understand now, but just so you know, common sence also says for someone that isnt sure of interchangability, how am i supposed to know that bp axles would fit in the mx3's wheel? and no im not questioning your knowledge on it, sorry you thought that. but also no need to be a jerk about it.
- Limegreen mx-3
mazdamx3sohc wrote:well i understand now, but just so you know, common sence also says for someone that isnt sure of interchangability, how am i supposed to know that bp axles would fit in the mx3's wheel? and no im not questioning your knowledge on it, sorry you thought that. but also no need to be a jerk about it.
BP axles will fit in a MX-3 wheel hub even the kia axles will fit..
Im not even going to go there with common sense
thats why u research so instead of how are u supposed to know turns into now you know..
im not thinking anything i just don't understand why u keep thinking u had to mod the axles when i stated u modified the half shaft and u keep saying how do i mod the axles and no one here is being helpful
where do u get this frommazdamx3sohc wrote: how am i supposed to know that bp axles would fit in the mx3's wheel?
the bp axles will not fit into a mx-3 transmission but will fit into the bp trans (forget the wheel) the other end will fit into a MX-3 wheel hub.
and the MX-3 axles are to small and will wiggle inside a bp trans..
does that help u out u don't get it do you.
I got a lot of work to turn u into a Mazda MX-3 specialist
no i do get it actually and yes my mistake for getting half shaft and axle mixed up. i wasnt trying to act like i know it all. sorry if you i gave off that impression, thanks for the help, im going to be boosting my sohc but not for a little while, what do you recommend for clutch? cuz i wanna put in a performance one even though im not boosting for a little while i still push it hard.
- Limegreen mx-3
act clutch
the dial friction set seems pretty good for the money and stuff and sounds very promising. or stage 2?
- Limegreen mx-3
i mean dual friction by centerforce
yeah dual friction im on my cell phone doing all this lol.
- Limegreen mx-3
ain't worth a shyt
dual friction centerforce couldn't even hold 8psi on my turbo setup
ACT im telling you.
ACT im telling you.
ok ill go with that then.
