Ok.. not many new pics at the moment.. but, I have finished a few more projects that I figured I would list here before I forget them all.
I painted the rear seat.. the ugly colored fabric part of the seat.. it didnt turn out too bad. I think re-upholstering the seat would be a better option, and I might get around to that eventually. But for the moment this looks ok. Here are a couple of pics of the paint I used and the seat. I used a broken rear panel to test the paint on before I hit the seat. The painted fabric is a bit rough to the touch.. but after using a hair brush on it.. its not so bad really. You will need 2 coats of paint.. the method I used was "Clean, paint, brush, paint, brush" This kept the seat flexible and got the paint into the little grooves of the fabric. Its completely flexible and doesnt seem to come off on your hands or clothes. Not my first choice.. but it worked ok. I got the paint at my local Napa store. Eventually I will be doing this to my door panels as well. But those are easy to get to. I wanted to do the rear seat before I reinstalled it.
Here is the test panel:
Here is the paint I used:
And here is the back seat:
I replaced the interior fuseblock, Thanks again for finding one for me Mark
Finally finished working on the clutch safety interlock switch. The pedal assembly was missing a part.. a stud of some sort that would push down on the plunger of the switch when the clutch pedal was depressed. Had to make one out of a bolt and a couple of nylock nuts. No big deal but was a pain to work on under the dash (yeah I know I should have done it while the dash was out but I had other issues on my mind then).
Got my new SS Brakelines in.. I'll install them right after I get the brake system flushed of all the crappy old fluid that is in it right now. Going to be using DOT 4 fluid. Hard lines are in good shape so this shouldnt be a big issue.
Dash is completely buttoned back up now, finished wiring in my autometer gauges so that all the lights are working properly. Also finished wiring in my Shifter knob so it lights up when the head lights are turned on as well. I'll edit this post and add some pics early next week. I also finished reinstalling the center column as well.
Projects left to finish phase 1..
Sunroof alignment.
Ceiling liner install, along with all the accessories (rear view mirror, visors, sunroof switch/dome light unit, etc..)
A pillar & door trim.
Upper B-pillar panels.
Rear Seats, Front seats.
Konig Helium rim install.
Alignment
Brake system flush & brake line install.
Front strut bar installation
Exaust system upgrade
Phase 2 projects...
Ignition System Upgrade
Window tinting
Alarm system
Stereo & entertainment electronics
This should be fun
Phase 3 projects...
Body work and Paint - nuff said.. this will take a bit of time - Front Lip, Euro Side Skirts, Wraparound spoiler, and rear mud guards
Phase 4 projects.
By this time.. the suspension will be needing some work I have no doubt. I'll spend a bit of time researching what I want to do here.
As you guys can see.. this car will be something of an on going project for me.. keeps me busy and out of trouble for the most part
Tunes67
