XBOX 360
- Ricksmx3
XBOX 360
Just recently bought a 360 and an extra controler. But when i plug it in and then turn on the 360 all the controler dose is blink and i cant get it to work. Anyone know why is there a special way to fix it or is it broke?
2010 MazdaSpeed 3
- mitmaks
does your xbox blink also? Im afraid you have 3 red lights
http://support.microsoft.com/kb/907534
You will have to either exchange it or repair it. Mine was sent out couple weeks ago and they're still repairing it....they suck. For a $400 unit this is shitty.
Are you talking about just the controller or the console? If it is the ring of death (3 red lights) I can do a repair but it will only last around 5 months. Otherwise you would need to contact Microsoft if you are still under warranty. If its the controller your talking about you have to press the button on the 360 console and the button on the controller till they sync up.
Im a potential scammer, do not sell me anything as I owe others $$
- Ricksmx3
Lights on the console are not blinking but the lights on the controller are and even when the 360 is off they still blink. Its a wired controller if that makes a difference. When i hit the connect button the lights on the console blinks in a circle then go back to normal. The controller that came with it works fine its the extra one that i bought that has the problem.
2010 MazdaSpeed 3
my wireless controller just started doing this right now...... im pissed cuz i was set to kick a$$ on madden 08 live
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
