Hey guys my parents are moving in about a week so I need to get rid of a lot of stuff NOW. All parts are located in Oakville Ontario, which is about 40 minutes away from downtown toronto.
1996 1.6L DOHC engine block (with pistons and everything in it) $30 PICK UP ONLY
1996 1.6L dohc rebuilt engine head $350 (JUST THE MACHINE WORK WAS $420) I WILL INCLUDE THE VALVE COVERS IN THIS PRICE
1.6L SOHC head gasket $50 (normally $100 from mazda dealership)
1994 1.6L DOHC intake manifold $30
BP throttle body. This will bolt on to the 1.6L SOHC engine. It's bigger than the SOHC throttle body. $30
Four 1992 protege SOHC injectors (used). I believe these are the same size as the 1.6L SOHC injectors, and will fit the SOHC too. Not completely sure though $10
New Centerforce Stage 1 pressure plate for B6. $60 VERY GOOD DEAL
ACT MIATA heavy duty clutch DISC 200ft/lbs torque capacity part#1000202 $30 ALSO A RIDICULOUSLY LOW PRICE
BP09 ECU $30 (this will raise the 1.6L SOHC rev limiter to 7500rpm)
PM ME FOR MORE DETAILS AND PICS. I DONT HAVE PICS OF EVERYTHING, BUT ALMOST EVERYTHING.
[FS] cheap 4 cyl parts
1993 1.6L SOHC. Mazdaspeed mounts, BP09 ECU, BP VAF, Fidanza miata flywheel, exedy miata pressure plate, centerforce mx3 disc, tokico struts, B&G lowering springs, and some sh***y motomaster tires.
I want the BP09 ECU does that $30 include shipping if not how much to 43055?
Last edited by danmyers686 on August 20th, 2007, 12:29 pm, edited 1 time in total.
Im a potential scammer, do not sell me anything as I owe others $$
- TREVO123
Does that heavy duty clutch disc fit the sohc mtx?
The miata clutch won't fit no... it might fit with a pro lx but the spline count is different for the 1.6L
- Nomad_69er
