Probinator Chip
Trevor
Probinator Chip
Post by Trevor »
I just got back from the Drag Strip after installing a Probinator chiped k8 ECU in my car. this is the only mod I did since the last time I was at the track and it showed no power imporovment. I ran the same time as i did with my KL31 ECU. The probinator chip was suppose to improve power right? What should I do? The Car runs fine with both ECU's the chiped one seems a little smoother but no HP gains.
2RotorsNaDream
Post by 2RotorsNaDream »
They said it improved power by like 5whp or something. Thats not going to make a very big difference at the strip.
Mnemonic
Post by Mnemonic »
yea man it doesnt give you that much power over the stock ecu (thats why there is such a split line between those who say use the jspec ecu and those who say use the probinator). 5 ponies can easily be made or lost depending on the situations of just how its running that day. its really just a cheaper alternative to using the kl31/36 ecu
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Vanished
Post by Vanished »
I know there is a big difference from K8 to chipped K8, but not a noticable amount between KL31 and K8Chipped. It's just way way cheaper to get it chipped, and it takes out your EGR code.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
hgallegos915
Post by hgallegos915 »
bleh its the same thing, just cheaper than kl31
-hec
Kveite
Post by Kveite »
But with the probinator, there is a different chip if you have the kl03 heads with ze manifold or a complete ze, also if you have the curved or strate neck.
ninjajim4
Post by ninjajim4 »
Vanished wrote:I know there is a big difference from K8 to chipped K8, but not a noticable amount between KL31 and K8Chipped. It's just way way cheaper to get it chipped, and it takes out your EGR code.
also gives you back your CEL, which is nice...
mx3autozam
Post by mx3autozam »
My chipped k8 seems to be working great. car feels really nice and propledd my car down the quarter in 14.4 seconds at 100mph.
Trevor. is this the same chip Ian,Mike,Krish and I are using? If so its made for kl31 cams with curve neck, but the vris points are also screwed up on it I believe. not sure if that makes a difference.
93 Mazda MX3 KLZE Turbo
