recommended wheel sizing
I looked up a 16" wheel on tirerack.com and the recommended tire size for the gs is 205/45/16. Is it much of a difference (performance/speedo reading) if I were to use a 205/40/16 instead?
'93 GS, Curved neck KLZE, KL36 ECU, B&M STS, complete SRD shifter bushings, mx-6 clutch, ZX2 struts, Apex springs... and building...
- solo_ryder
- ScooterBovine
205, 215 is the width and 40, 45, 50, 55 is the hight of the profile of the tire( how tall it is, and sidewall). The last number is the rim size.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
1st - if you're gonna use this resource, learn how to use it... Search Function is your friend.
Ok, now that tat is out of the way...
Try http://www.miata.net/garage/tirecalcold.html ... and book mark it.
While your at it, you may wish to consider the effect of the added weitght from stepping up to 16" .... use http://www.wheelweights.net/ to look up your wheel weight add to tire aned compare to other options... keep in mind that adding weight at the wheel is unsprund weight which means the engine works harder to get it moving, the brakes work hard to make it stop and the suspension has to deal with the weight as well... in general, lighter is better all around from a perfomrance standpoint.
Welcome to this little corner of the interweb and enjoy your mx3!
-Barney
-Barney
93 GS SE
Smith18 wrote:205, 215 is the width and 40, 45, 50, 55 is the hight of the profile of the tire( how tall it is, and sidewall). The last number is the rim size.
the 45 50 55 is the sidewall height (rim to road, one side) of the tire expressed as a percentage of the width...
a 205 50 15 is 205 mm wide, 102.5 mm from road to rim, and takes a 15" rim.
The overall height of the tire in this case would be 15" + (2 x 102.5 mm)
93 GS SE
- atlantamx3
Hey, those links are a great help. Thanks.PurpleDinosaur wrote:1st - if you're gonna use this resource, learn how to use it... Search Function is your friend.
-Barney
I think this info should go to the FAQS.
