Man it's one problem after another. Havent' been able to log on for almost a week. Well I'm still in Savannah, leaving tomorrow, my professor screwed me on grades and I've been working with the chair and dean to resolve them. If things work out, I've graduated. I'm gone from Ga, but I'll be back, have to move out in January and my girlfriend still lives down here. As far as the car goes, I'm not sure what throttle body I have. That's a stupid response I know, but as long as the place that sold me the engine didn't screw me, I'm using the one that comes with the curveneck ze, je50 vaf and the kl36. Things I haven't mentioned, is that if it were the timing, the car would run like crap all the time and also at idle, wouldn't it? It only does the misfire under acceleration and at cruising. Something new came up though, I got a chance to run the car for about an hour to an hour and a half and the miss went away. The car was running perfect. I let the car warm up to about 100-150 on my water temp gauge before I start driving it depending on the rush I'm in but the overall engine is still pretty cold, although after driving the car for a longer period of time of driving the car at around 208 to 214 degrees, the engine's misfire disappears and runs perfect, I think eliminatiing the timing issue. I also think that probably eliminates the injector issue as well. My girlfriend's brother, remembered that when her father and I built my exhaust, we used a test pipe and eliminated the catalytic converter. Due to the serious drop in backpressure, O2 sensors are probably the culprit, although sticky throttle and tps are probably not helping. Since the o2 sensors mount in the manifold I didn't think that removing the catalytic converter would effect them that much. So going back to the original recommendation, does the car warming up completely and running fine narrow it down to possibly those o2 sensors? I admit, I know for the most part what parts deal with air/ fuel, and what parts deal with spark, etc. etc. and if you give me a bunch of tools and tell me that I need to start replacing this and that, I'll have no problem tearing into the engine, but as far as diagnosing things, I'm still learning as I go. This is
my first swap. Before I basically slapped bolt ons on everything I've owned. So sorry if I'm a pain in the @rse..... I blame it on fuel injection and electronics......
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain:
http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
