crank sensor
crank sensor
one of my codes is for the crank sensor, and somebody said to take it out and clean it befor buying a new one, can anyone tell me where that is located and how to clean it thanks
1992 Automatic Mazda MX-3 GS
- XxantwawnxX
Its right next to the Crank pulley. Yo have to go under the car to get it. If you follow the dipstick tube allllllllll the way down it ends you kinda near it.
