Ordered Fidanza 9lb flywheel + clutchmaster stage I
I just ordered them in prep for my KLZE swap.
Anyone have them together here? I talked to a few probe users who love it. The stage I is apparently good to about 220ftlb which is more than anything I'll see at least for a year or two.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
I had that kit to start with only mine was a CM stage 2. oh and get the SS clutch line if you don't already have it.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
i had the Fidanza +CM2R and well i cant give any good comments about the CM clutch as it only lasted 5k before it died, i looooooove a fidanza on a ze, though it can be a pain at times
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- XxantwawnxX
I dont understand why people say the flywheel is a pain. I barely notice any difference in drivability at all.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
hehehe drive in downtown atlanta traffic durring rushhour and you will know why:)XxantwawnxX wrote:I dont understand why people say the flywheel is a pain. I barely notice any difference in drivability at all.
yeah I don't really notice any driveability issues but I guess that's because I've driven it for almost 5 years ![Smile :)](./images/smilies/icon_smile.gif)
oh and I should've said BOOO on the CM2R - I only got 18k out of mine
hope your CM stage 1 lasts longer than what we experienced... I DON'T recommend Clutchmasters! plus when it went out I had to replace my flywheel surface (another $60 but at least I could replace it)
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
its not that its a real issue anymore, its easy to drive just can be a bit of a pain, when you have to bounce from all the gears a lot, but now i just keep it in 2nd don't ever really have to shift down to 1st.
Yea clutch Master sucks, its ashame that RR racing doesn't give you a choice in what clutch you want with the package.
Hmmf.. well that's too bad.
I'm pretty hard on my clutch too.. :/ But anyway in the next year or two I'll probably be bolting on a SC or turbo kit so I'll have a chance to inspect and replace the clutch then if it goes bad.
- Gord
