KLZE owners
KLZE owners
Just wondering, how many of you that has the KLZE is running with synthetic oil? Because I don't have the guide/manual for the KLZE, I'm wondering if it's a recommended oil or if I should just use the "dino" oil.
Thanks
Thanks
'93 GS, Curved neck KLZE, KL36 ECU, B&M STS, complete SRD shifter bushings, mx-6 clutch, ZX2 struts, Apex springs... and building...
- PATDIESEL
Surely most of us use pure synthetic in the ZE. It costs too much and hauls to much a-- not to
I dont...BUT im about to
-hec
i use castrol gtx 10w30
i put over 40000 kms of me beatin the hell outta it in a little of a year of me .....just pulled a 14.6 @ 153.4 kp/h last night
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
- mx3autozam
Been using Synthetic since we did the swap over 3 years ago. Using QuakerState 5w40
I thought Castrol and Quaker and even Mobil were looked down upon when it comes to synth oil? I guess using Mobil isn't so bad then.
Maybe I could save money with Castrol
- PATDIESEL
Hmm, from what I've heard the oils are not bad, it is the filters that they make that are not the "best". I use Mobile 10w30 syn. in all my cars.
- solo_ryder
Mobile 1 5w30 or 10w30 depending on the car for all my cars!
I use cheap filters but never a fram filter (junk).
Change my oil about every 5000km (first few after switching to synthetic at 3000km just to get the dirt out)
2002 Mazda Protege5 (Turbo kit 75% complete)
1996 Mazda MX-3 Gs KL-ZE
1994 Mazda MX-3 Rs (BP-T?)
I used mobil 1 full syn 5w 30 (and mobil 1 filters) for 3 years but finally read that castrol gtx regular oil was almost just as good if not better! however the mobil 1 extended performance ranks right below amsoil...
then of course I read about amsoil and I have been using it for about 6 months now in both my cars (5w 30 and amsoil filters). I have noticed that they burn much less oil now and I have seen slight improvements in gas mileage...
amsoil FTW
amsoil FTW
- mazdaspeed23
Re: KLZE owners
i use pure synthetic in both my klze's
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
