11.2 any good for stock sohc?
- 10secSim
i'm planning on boosting soon but i hope to see some positive results until then.
B6 1.6L DOHC, CAI, custom intake mani. with internal velocity stacks, 65mm thottle body, probe 4-2-1 header, custom 2.5" high flow exhaust, Centerforce dual friction, MS2, MSD 6A, Tokico struts, EIBACH springs.
http://www.cardomain.com/ride/2443642" onclick="window.open(this.href);return false;
Are you smoking something mazdamx3sohc? With equal amount of money spent there is no way a sohc mx3 will be close to a BP mx3. A sohc mx3 is 88hp stock while a BP mx3 is 130hp, also you will see far better gains per psi on a 1800cc dohc engine vs a 1600cc sohc engine.
What is so hard to understand here?
I am sorry if this comes across as being harsh but it is fact.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
I look forward to you proving me wrong, all the best in your project dude.
Always good to see another turbo MX3.
- Limegreen mx-3
his rite my boosted sohc MX-3 is going to be no where near as fast as my boosted BP MX-3.
- Limegreen mx-3
what im tryin to make it the fastest boosted sohc mx-3 in the world. i know i can. probably doing up your bp alot more then the sohc my azz. my project sohc getting all the good shyt tial, TEC II, percision turbo, msd, ngk, act extreme, name brand shyt my friend. i can probly get the low 13's when im done wit it.
- Limegreen mx-3
maita act extreme clutch rated around 300ft/lbs of torque. if i make more than that slap on a g-series trans i already have a coustom half-shaft for it made. al that good g-series stuff. who u think ur talking too.
- Limegreen mx-3
[quote="mazdamx3sohc"]nice, so your using a sohc tranny and all that still? thats spectacular.[/quote]
yeap on my bp setup on the f-series trans i ran a 12.8@110
