power steering pump???
Ok so lately my power steering has been making a sqealing noise while turning. It is full on fluid (located near the oil sipstick correct??), i can still turn it a lil but it sqeals so do you guys think it is going bad on me? will one off a 93 probe gt work? do the 4 cylinders have power steering pumps that i can use, etc?
Check belt tension and tighten up the belt...
94 Mx-3 Precidia
If the belt is loose enough to not run the water pump - then it will be squealing all the time - not just during turns. Also check PS fluid level and condition - maybe a flush is needed too.
94 Mx-3 Precidia
- Tunes67
The water pump turns a LOT easier than the power steering pump.. the belt would have to almost be off before it would stop spinning the water pump.
Tunes67
Tunes67
k, the fluid is full but kind of a brownish color, so should i flush it and how?? also i will check the tension on the belt tomorrow also. again my belt is not sqealing all the time, just during turns and the temp is staying normal as always, just no power steering now and sqealing while turning it.
- Tunes67
So your saying the belt squeels during turns and you have no power steering at all? And the fluid is brown? Power steering fluid is clear usually.. so it sounds like yours has definitely been abused. So flushing the system would be a good idea. I am sure you can find details about how to do that in the online shop manual located in the left column of links on the main mx-3.com home page.
Tunes67
Tunes67
- PATDIESEL
I think that you jack the car up, disconnect one of the lines at the rack, then turn the wheel from lock to lock until you are out of fluid. Then repalce the line and fill the fluid, turn the wheel from lock to lock until it quite accepting fluid. Drop car, crank, turn from lock to lock and check fluid level. Pretty simple really. However, check your belt tension and belt condition first. If the ribbed side of the belt shows cracks when you flex it then it needs to be replaced.
I just finished installing a new pump on mine. mine was squeaking side to side at first but then it stpped. The belt was new so i am thinking that it just needed to worked in a little. Its really easy to change a pump if need be. the 4cyl ones wont work but any KL series 6cyl will work. I got mine of a probe.
