Cruise Control
Cruise Control
ok i've pu a ze in a 94 5 speed v6 GS with kl36 ecu. since then the cruise hasn't worked. i hooked everything up properly. is there something i can do to fix this or is it the ecu doesn't operate cruise.
- PATDIESEL
It should work fine. There is a MOCA member with a KL36 ECU and he still has cruise. I would bet that your vacuum is crimped or not constant to the cruise canister. Check where you have it coming from. It should coming from a place in the intake that has constant vacuum.
- mx3autozam
ya connect the vacumn line. the ze intakes don't have the small nipple on the number2 runner. so make the line longer and ring it under the spark plug wires and the vacumn line for the fpr put a tee on that and connect it. Should work then, make sure the tee is before the fpr solinoid if your still using the solinoid
93 Mazda MX3 KLZE Turbo
