my supercharged klze
hyperman
I'm runnig a 255lph walbro pump with 370cc injectors. I dont have a afpr at the moment but I'm using megasquirt to control the fuel.
daytona blue MX-3 2.5L V6 KL-ZE, KL31 ecu, koni lowered 40mm, freeflow exhaust system (decat), centerforge race clutch, cold air intake Dynamik, front and rear strut bars reactive, OBX race headers, Akebono pro act ceramic brake pads, Techna fit steel brake lines, zimmmerman crossdrilled rotors, reverse glow gauges, spinner gauges, topmix front lip, pakfeifer skirts, pakfeifer difussor, pakfeifer wing, inverted scoop bonnet , 17" bsa rims, etc
- solo_ryder
Sounds good, where did you get those injectors from? Are they modded sr20's? As far as I know we should have no issues running the Millenia Blue Tops though for a application running 5-8psi of boost. Looking forward to seeing some more pics.hyperman wrote:I'm runnig a 255lph walbro pump with 370cc injectors. I dont have a afpr at the moment but I'm using megasquirt to control the fuel.
hyperman
It are sr20's, the purple ones in a modded rail. Millenia's will indeed be sufficient for the setup, but they are hard to get around here.
- PWRD_BY_HKS
hyperman, no news on the numbers ??
I am waiting for them, hurry up
You take so long, it seems you have a K8 ... heheheh ( I have a K8
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
- mx3autozam
