has anyone ever seen this before? I deffinetly haven't and I'm surprised that it hasnt been big news
http://ebaumsworld.com/2006/06/waterfuel.html
water powered car
water powered car
1993 GS
-MS front -functional molded hood scoop
-MS molded sides-shaved antenna
-Civic projectors -New black paintjob
- XxantwawnxX
wow.....that should be sumthing to hype up...
- 1992blazeredgs
O wow they are developing a water powered hummer... is this a REAL news article?
-hec
I might be wrong...but I believe he's not the first to do this.
Goog god, we should all be using this technology.....should have been for the past 50 years.
I hate to say it, but he'll probably be assasinated within the week and the idea buried under a rock in some oil executives cottage yard.
Thanks for the post! I downloaded the vid and am sending it to EVERYONE I know that would give a damn...
Cheers, Josh
Cheers, Josh
