is it normal
is it normal
is it normal for the v6 engine to be hesitant when cold?
- jschrauwen
Re: is it normal
Normally no, not if it's tuned correctly. Your idle screw adjustment is probably the player in that.MX3KEV21 wrote:is it normal for the v6 engine to be hesitant when cold?
- PATDIESEL
My God, quit starting so many threads. Ask ALL the questions about the same problem in one thread. They are all linked and you are making a mess of the forum. I know you are new and obviously new to forums. It is appreciated if you would follow some sime guidlines.
1. search for the answer to your question before asking one,
2. Post one topic only, in the correcty section
3. reply to that one post with more questions if they come up so that we can see what was said and try and help you.
