I own a 1991 Mazda MX-3 (Eunos Presso with K8 engine).
I noticed that the level in the automatic transmission is dropping fast. When I look under the car I see that a large area is dripping wet with oil.
When I looked under hood I noticed that there is a lot of ATF *on top* of the box. You all know there is a lot of stuff blocking the view with this car, and the drawings in the online manual are a bit too small to shed some light on what is on top of the box that could be leaking.
The transmission works as good (or as bad) as it always did. I remember hearing someting bouncing under the car when I was driving last week.
Perhaps a bolt or cover loosend and that's what I heard bouncing off the road.
Does any of you have any idea if there is something on top of the box that would cause spilling of ATF when it gets lost? A (link to a) picture perhaps?
Arjen.
ATF on top of transmission
- Aston Wards
couple of things..., is the dipstick inserted tightly? and are you sure it is ATF fluid? (red) oh yeah, has it been topped up recently? cos it is easy to spill ATF in doing so!
check the ATF level, clean up the spill as best you can, then keep an eye to see if it reappears..., that's the best i can come up with, s'been a while since mine was auto
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
Yes, it's red, the dipstick is all the way down and the tube is dry as a bone. Not topped up for months now.Aston Wards wrote:couple of things..., is the dipstick inserted tightly? and are you sure it is ATF fluid? (red) oh yeah, has it been topped up recently? cos it is easy to spill ATF in doing so!
What I could try is find a pressure cleaner but if there's an opening the box get 'topped' up with H2O...check the ATF level, clean up the spill as best you can, then keep an eye to see if it reappears..., that's the best i can come up with, s'been a while since mine was auto
Arjen.
- Aston Wards
I found what I think must be the culprit. On top of the tranny there are a few things that look like a disk with a protruding center held in place by a circlip. I found the circlip of the rear one like this:Custommx3 wrote:Could be where your speedo gear is mounted to the top of the tranny.
http://www.pbase.com/image/72729416
I lost close to a liter of ATF.
Arjen.
