W.T.F IS THIS?????
- PWRD_BY_HKS
W.T.F IS THIS?????
http://www.youtube.com/watch?v=3NGqT-NZqZE
sersiously who do i have to slap for this one
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
That would be rsroadkilla's car. He's done extensive modding to his car in a very short time.
'92 GS
My worklog
My worklog
- XxantwawnxX
Yeah the car looks good in my opininon and if hydraulics are not your thing then just say so, no need for slapping : ).
Lotsa work done to that car and i can appreciate it.
- mitmaks
hydraulics are for impalas
yeh mx3 is not for hydros. Still i give him props for the works done. Im sure hes won alot of shows. If my brothers ricer cavalier has won.. haha this one is WAY WAY 100X better.
-hec
- PWRD_BY_HKS
im just saying ...you wanna be gansta ...then hustle on am impala, a monte carlo, man even a mini truck but an mx....NO man ....
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- XxantwawnxX
omg stop with the stereo types hahah, who said he wanted to be gansta..u can have hydrolics and not be "gangsta" : P some people just like hydro's
- papa roached
STOP THE HATE!
- hotsiit
I agree with papa roached and XxantwawnxX
rsroadkilla...I like your car and the work you have done to it...hell, I'd like to have hydro's (or airbags) for the fact that it would be so much easier to drive over big bumps or dips in the road by raising it up.
Nice work, later!
Nice work, later!
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
- rsroadkilla
just seen this topic!!
Yeh its mine <ducks>, im no gangsta...
see!
Thats me on the right
And in all honesty, the main reason for the hydraulics were due to me having a steep hill to get get into my drive, and it used to scrape at standard height!!!
I dont usually bounce them about, that was just for my mate who wanted to record it for a video he was making!
see!
- mitmaks
Air suspension maybe...hydros NO. I just dont see bouncy mx-3's. Of course it has to be fast before "sho"
