more info on 2.5 swap
mex4life2488
Post by mex4life2488 »
well i was wondering will the 2.5 out of a prob fit the wireing and the tranny in my 92 gs mx-3 and will the valve covers fit and the intake fit it also so its doesn't say ford on it?
solo_ryder
Post by solo_ryder »
Those are some common questions, and the answer is basically yes to all of them. The tranny in the probe and mx3 are basically identical, the engine is compatible and will hook right up if you get a OBDI engine (93-94 probe). The block is the same size so the valve covers are interchangable as are many other parts outside of the motor.
There may be a few things that you have to do, but there is lots and lots of information on this site. Do a search for "KLZE Swap" and choose the "Search for all terms" choice and pick the V6 forum as well to search in. (KLZE is basically the same swap as the ZE except you need a different ECU and airflow sensor)
You can also check out our FAQ page here, it has some more info. Also here is some more links to swap pages:
FAQ:
http://www.mx-3.com/phpbb2/viewtopic.php?t=34783
MOCA page:
http://www.atlantamx3.com/mocaforum/viewforum.php?f=7
One more:
http://www.mx-3.com/swap/ze-swap.cfm
There is many more out there to as well as answers to pretty much all of your questions, good luck.
