why do some people call it mx3 ze a GSR
hgallegos915
Post by hgallegos915 »
Ok.. I know alot of people are probably going to get mad... BUT..
Why call an mx3 ze a GSR? Is that not like comparing to an acura?
I dont think mazda would have called it the GSR. People mean R as in racing? Kinda like the civic type R. I know my car looks like rice but I would never dare call it a GSR. Its just an mx3. What are all of yours opinion? I respect everyone's opinion btw.
I prefer local people now know that I got a ze tho. The shock in their faces is a great reward for your swaps.
-hec
solo_ryder
Post by solo_ryder »
the v6 is a GS, the R usually means it is a higher model or a rarity of somesort. So doing a swap can make is a GSR or a GSZE, not a very hard thing to figure out. It has nothing to do with Acura IMO.
johnnyb
Post by johnnyb »
people started adding "R" during the whole type R craze. If it were to be badged by mazda it would more then likely be badged the mx-3 GT.
hgallegos915
I like mx3 GT but i guess that would apply to a de mx3.
-hec
Well,my guess it would be in relation to the GSR of an Integra, but it does make sence. The Integra has a RS and GS models (as well as an LS in the middle). The next step, a swapped GS with a KLZE could be a GSR. The integra GSR has 200hp, as wellas would be an ZE Mx-3. Add that with the type-r craze, and it does in a sence make sence.
mx3autozam
Post by mx3autozam »
Nd4SpdSe wrote:Well,my guess it would be in relation to the GSR of an Integra, but it does make sence. The Integra has a RS and GS models (as well as an LS in the middle). The next step, a swapped GS with a KLZE could be a GSR. The integra GSR has 200hp, as wellas would be an ZE Mx-3. Add that with the type-r craze, and it does in a sence make sence.
umm mike the integra gsr is 170hp..the type r is 200hp
93 Mazda MX3 KLZE Turbo
johnnyb
Post by johnnyb »
hgallegos915 wrote:I like mx3 GT but i guess that would apply to a de mx3.
well then if you wanna mark all the cars it would probably go as such
RS = stock 4 banker
GS = V6
R/T = turbo 4 cyl
GT = DE
GTS= ZE
hgallegos915
See i like those :)
cept the gsr, makes us wanna be inegras.
-hec
atlantamx3
Post by atlantamx3 »
Well TECHNICALLY.. its 195hp for the Type R
~Perry
Please visit
http://www.mx3-atlanta.com
XxantwawnxX
Post by XxantwawnxX »
Who cares, call it what ever you want sine it was never made. Personally i think mx3 gt sounds...crappy. GS-R sounds better since it uses the GS thats the car is already named. I also like GS-ZE.
lol, agree
For a while, people were using these naming schemes
RS
GS
RSR
GSR
RSR-T
I don't think I've ever seen GSR-T or GS-T used before.
Steeb
Post by Steeb »
atlantamx3 wrote: umm mike the integra gsr is 170hp..the type r is 200hp
Well TECHNICALLY.. its 195hp for the Type R[/quote]
totally correct!
195 hp type r = 200ps
195hp klze = 200ps
really tho i think 200ps is closer to 197 hp :wink:
gsr is fine for evo's and integra's but they come with that badging from the factory. its a common swap now so why not just the people that know know and the people that dont wonder.
PWRD_BY_HKS
Post by PWRD_BY_HKS »
HECTOR be honest is this about my
MAZDA
G S R
look it up
i did it because at the time there was only another ze in the 915 area and noone even knew about it so when i got mine i wanted it to be known that i cared about my mx and i had more than just a drop and rims so i went ahead and got it done..... this was bacause there is a link some where on this web site and it says "MX-3 GSR" and so thats where i got it from
the look it up part was so that people didnt think i put a honda b18 motor and would rise the curiosity of a "MAZDA GSR" go to google or yahoo or what ever type in mx-3 gsr and it will show pix of klze mx-3 ..... thats why i went with GSR and not MX03 Jdm, or GS-ze
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
hgallegos915
Imma label mine mx3-ZE :) Imma see if i can get plates like that.
It was not about your car tho. I had seen it here. A local friend asked me if I had an acura engine.. lol
-hec
timpronk
Post by timpronk »
How about a GSS (super sport I think), as in the chevy camaro ss? Different and not acura related. Using the same style as the "s" that is already on the gs.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
