In this picture, i have put 2 letters.
I really want to know what are these tubes for.
If someone could help me please
The A tube, is it a leftover oil tube ?
And the B tube ? mine is disconnected ... it is only with some "cork" in it
HELP !
Hi schrauwen,
I have now bought and am ready to install the CAI ( hoodzy how to ) dismantled the stock intake okay, but I have one question.
****What are you doing with the small ?vaccum? pipe, just in front of the VAF on the airbox. *******
Its a 4mm internal diameter rubber tube.
Thinking of tapping a line into the piping, I have the technology, does it need to be before the VAF like the oem fitment ? Its a lot eaiser to run it to just after the vaf and before the throttle body .........but do I even need to bother, can I blank it off ?
I have been searching the online manual for it, and I can't find it.
You can see it on this pic ( also showing the bonnent stay mod ) between the vaf and the bolt for the OEM air filter housing.
http://www.jaywave.net/img/ze_07.jpg
Hi Silver
It's a common query that people have when doing the CAI install. Go to http://www.mx-3.com/index.cfm and go to the online shop manual page F2-006 and F2-007. Although the first page is much better and you'll see your vaccum line that you're referring to. It needs semi protected air but not a vaccum source. It goes to the EGR Vent / EGR Vaccum Solenoids that are normally attached to the rear side of the IM not far from the TB. It's not a vaccum line at all. Now you can simply plug it if you're not running an EGR system in your MX. I believe you're running a ZE, correct? Which doesn't normally come with an EGR but there have been a few that have migrated their EGr to the ZE engine for emissions purposes. Although I don't have an EGR, I still have the 2 solenoids in the car if the need should ever arise for me to re0install and egr in the future. So I just have the whole hose removed completely exposing the nipple of the EGR Vent Solenoid. I hope that helps you with that. What I should make mention is that you should retain the PRC Solenoid that was attached to the side of the airbox. It has a 2 wire connector attached to it the traces back into the wiring for the VAF. That PRC Solenoid is connected to the FPR and it's vaccum source should be nearly beside where the FPR is attached. Basically, going by page F2-006 you'll see how the vaccum is routed from the vaccum source to I believe the bottom of the PRC Solenoid and then back to the FPR. You'll probably see my posts wrt to it's purpose when doing a search on "PRC" or "FPR". Hope this helps and good luck, cheers,
