![Confused2 :confused2:](./images/smilies/confused2.gif)
Hei/msd coil mod problems
- FIMotorMX-3
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain: http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
check out myspace:
- PATDIESEL
I haven't had to do the mod yet, but it def. sounds like a wiring issue or something in the tach signal. If the signal is not there the sparks will not fly (if they did then I'm quite certain you'd need a new motor so thank Mazda for that). I'd start from square one and recheck everything. You are sure to find something that looks amiss and then have a place to start diagnosis. I'd start with the disty, focusing on the cam sensor. Funny tach signals, funny idle and no fire on the freeway all point to something in the cam sensor.
argh mine startwd acting up and its probably bad grounding. :/ it drives fine and when i floor it.. PRRRPTTT PRRRPPTTT ROOOOOM ... eh ill rewire the whole thing.
-hec
fyi i fixed it. it was wiring problem. I hope that was it.
-hec
- FIMotorMX-3
I completely removed the coil from the disty. I cut off the post that connects to the coil and i rtv'd the connection at the power tower as well as the point where i cut the post. I am assuming that the three metal prongs that connected to the coil were the internal ignitor that is supposed to be cut. Since I removed the stock coil, do those three prongs need to be cut still? I grounded the Sheet out of it.. it's mounted on a metal bracket like gro's install, grounded through the center holes as well as one of the four prongs on the hei was a ground. I guess I could retry the grounding it. I have been driving it sparingly and expected to check tdc and throw a timing gun on it as well. I'm assuming that disassembling the disty could have effected the timing as well. Does anyone know the wattage of the resistor needed for the tach wire? i know it was a 1000 ohm resisitor but there are different wattages. I'm assuming the cam sensor is one of the wires running off the harness on the disty. I'll do a search on that later. Thanks for the info and let me know if anyone thinks of anything else it might be.
check out myspace:
check out myspace:
The stock ignitor needs to be disabled - it needs to be taken off the circuit entirely. If the stock ignitor was bad to begin with and is still in the circuit - it will affect the new module's operation.
I used a 1kohm 1watt resistor.
94 Mx-3 Precidia
i had the same prob but i new it wasnt my wiring or the way i grounded the module cos i always make sure things are dun proply it was the cars stock grounding pionts so i just run a new ground going from the battery to the same wall the hei was on that seemd to fix it but id still like to redo al the ground piont just to sure
read my thread. same problem..well sorta.
-hec
- FIMotorMX-3
I'm in the process of getting ready to move over the next few days so the car is parked because I'm so busy with work and the move..
But I'm definately going to go through the wiring. I'll also make sure I disable that ignitor. The car has never done this before wiring this mod. I thought by removing the stock coil it automatically disabled the ignitor but I'll take it apart again and make sure all that is diconnected properly and see if that's the problem. While I'm doing that I'll get the car to tdc and make sure that the timing is correct. I'll also go over the grounds, although I grounded the sheet outta that thing. If all else fails I have plenty of pavers in my yard. I'll be sure to aim right at the windshield when I throw one. ![Rant2 :rant2:](./images/smilies/rant2.gif)
check out myspace:
check out myspace:
- FIMotorMX-3
Well tonight I jacked up the car and brought cylinder 2 up to tdc. The rotor was no where near the number two ignition wire. I'm wondering how the thing was running at all no less 80mph speeds.. the entire disty cap and rotor were covered in what looked like soot.... I disconnected the internal ignitor. loosened the screw to adjust the rotor and reassembled. The car started up and idled nice and smooth but at 2000 rpm. I took it for a ride for about a half hour and the car was ok. It had some misfiring at first but after about ten minutes or so it stopped. Rpm was fluctuating a lot at idle after about 10-15 min of driving. I finallly brought the car back and let the car idle in the driveway. rpms dropped to 900 and surged between almost 0 and 900 rpm almost stalling out completely multiple times. Something is up but not sure what. I still haven't redone the grounds or put a timing light on the car yet. I have to borrow the timing light and it was getting late to start rewiring things. So the problem is still not resolved but I located a couple problem so I'm narrowing it down. Does anyone know why there is so much black dust (soot maybe) inside the disty cap. The whole thing was coated. This is new since I've done the hei and coil mod.
check out myspace:
check out myspace:
New cap and rotor will solve that. The first time I did that mod my spark tower was too deep and the rotor was hitting .
93 gsr,KLZE with millenia intake, phenolic spacers, HKS intake, limitedslip-auto to manual conversion,centerforce clutch, 75hp NOS wet kit, MSD with blaster coil, white gauges, pacesetter shortshifter, Tenzo seats, lowered 2 inches, Konig Traffik white rims, cat back exhaust
- FIMotorMX-3
I'll try that out and see how that works. I''m assuming that you are talking about the rotor hitting the tower that's causing the soot inside the cap. I'll give that a shot. It's cheap enough. Hopefully that's causing the misfire and part of the crazy a-- idle? One could only hope. I'm assuming the rotor hitting and not spinning freely could possibly cause a sporadic fire... I don't know. I've been up way too long and I think I could convince myself of anything at this point.
check out myspace:
check out myspace:
- tehbrookzorz
Also, sounds like you might benefit from checking your plugs.
Since your timing was so far off, I'd bet the fuel mixture to some of your cylinders was well, off...
So that might not be contributing to the best conditions inside the cylinders, and your plugs may require attention.
Just a guess, I haven't had this issue, yet. (hopefully never will)
Aside from that, if your plugs are grungy, a shot of Lucas Upper Cylinder Lubricant/Fuel Injector Cleaner probably wouldn't hurt either, should clean up the tops of your cylinders and the valves.
I wonder if that could have throw off your timing belt at all.
Of course, do the usual check for vacuum leaks, bla bla, and checking TPS and IAC positions may be wise.
I can't wait for my KLZE.
Cody
![Image](http://i.imgur.com/Q0Vh17N.jpg)
- Custom_V6_Limited_SE
Next time you run it, pop the hood and listen carefully for a clicking sound. If you hear one, it is sparking out somewhere (most likely in the disty).
'93 MX-3 GS SE:My Mods
