wheel bearing
What are good lowering springs for the MX-3? How low should I lower it? Can I cut my springs instead of buying new ones? This forum is for Suspension related Frequently Asked Questions.
patto
wheel bearing
Post by patto »
hay guys my rear left wheal bearing hase created this droning noise not sure why. My ? is can u get a better quility bearing than the skok ones or should i just go down to my local bearing store and get em from there. cheers for any help
lakersfan1
Post by lakersfan1 »
The rear bearing is bought as an entire assembly with a new hub. Buy a new or remanufactured hub.
mx3autozam
Post by mx3autozam »
there also pretty easy to put on too
Its also recomended you do them ijn pairs. If one is done the other will be soon
93 Mazda MX3 KLZE Turbo
Return to “Suspension/Brakes/Wheels/Tires FAQ”
