power steering questions
GreenMachine
Post by GreenMachine »
Ok I am almost complete with the ze swap and no power steering is a decision made a while ago. But I was an idiot and welded the bolts shut thinking the rack would work like that. well now that I know my car can only turn about 4 degrees in any direction, I need to put the power steering resivor in. thats the back story now the question, does any one know the thread size of the bolts going into the power steering rack? IN the manual page N-20 it is the bolts labeled A & B. went to the plumbing section of the hardware store and tried the closest looking to the bolt I had and none of the NPThreads would line up. anyone able to help me here?!? thanks!
-Chris
wagZE
Post by wagZE »
FYI I put my ps pump on my ze and just never filled it with fluid. the belt turns fine & i dont get power steering personally i like to "feel the road" better when i'm driving like the maniac i am. But to answer your question no I dont know the bolt size/thread length.
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
GreenMachine
Yeah i personally prefer the feel without it as well, leaving the pump on wasnt something I was interested in though so When i took it off i just bought a 30 in 4 groove belt and had napa order me an idler pulley that had the grooves so I could loose the weight of the pump as well.
Steeb
Post by Steeb »
after driving the same car one equipped with ps but disabled and one equipped with a manual rack, i can seriously say that the disabled ps rack is much less responsive and by far much harder to turn the steering wheel.
wagZE
Post by wagZE »
manual rack meaning?????
4 mx3 GS SOLD-
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
A mannual ie NON power steering rack from any BG chassis
mazda or ford fits straight in , more turns lock to lock than the
power steering rack, but imo if you remove the power steering
system this is need!
PATDIESEL
Post by PATDIESEL »
I agree with Kiwi. The swap is a pain in the butt cause the rack is so hard to get to, but it will be the only real way to drive, feel the road and not need steriods. Also, the correct way to make a power rack a manual one is to loop the outlet hose to the inlet hose with a custom bent metal or flexable rubber line. Leave fluid in the rackas it is needed to lubricate certain parts and seals. Also, the loop is needed so that the fluid can flow from one side to the other. That is why yours will not turn, the fluid cannot go anywhere.
Steeb
Post by Steeb »
yes kiwi has it summarized exactly the way i would put it.
btw, i fabricated a line to connect 1 and 2 that way it could still hold fluid to keep the rack lubricated. then i sealed the holes in 3 with some bolts to keep dust out.
while it is very much still drivable, it does reduce the steering feel of the car substantially and like 10 million times harder to drive and 50 million times harder to park than the manual rack that requires more turns. not worth disableing the ps rack imo. it is only fun for the first week or so because your revs are much faster.
swapping out the steering rack is fairly easy, it can be removed from either passenger or drivers side wheel well.
GreenMachine
So if you were to use a rubber hose to loop the system on the number 3 bolts on steeb's photo, how would you go about getting fluid into the hose? would air in the system prevent it from lubricating/functioning properly for extended periods of time?
Steeb
Post by Steeb »
if u connect 1 and 2 the fluid will back flow into each other. i filled the fittings in 3 with solder to keep dust and air out.
PATDIESEL
Post by PATDIESEL »
You could connect one end of the hose then fill it standing up then connect the other end. That would seem to be the best way to get it full. It will hurt the seals over time, but I bet we are talking a good long time.
From what I've read I wouldn't do it though. Get a manual rack if you really want the extra power.
wagZE
Post by wagZE »
ahhhh... very nice. so like a ford escort manual rack? Ya know those are great ideas, I have been runnnin with no fluid in my power steering for over a year. My girlfriend loves the muscles it has given me.
4 mx3 GS SOLD-
Steeb
Post by Steeb »
who needs rebull, no power steering gives u wings for free
