Burning oil ....BAD
JWMotorsports
You may want to consider a Mega Squirt for the price.....but only if your familiar with wireing.
ModMX3 - (Carmaster2005)
Hello everyone ! Turns out at least 2 of my pistons are melted, everything else appears to be fine like rods and cap's. Does anyone know anywhere to get cheap replacment pistons and bearing's ? I allready have the rings, this would help me out drastically. Thanks everyone.
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
