Best song to bump to.
Wow. those are all nice selections..... but, I believe the best ones hands down are:
The Saint soundtrack........ This CD has got to be one of the most underrated CD's of all time..... but it is 100% pure hotness! It has techno out the A$$! I wasn't into techno at all untill a co-worker about 6 years back turned me on to it. And the bass hits.... REALLY HITS....It even has 2 very tight slow jams at the end...Heck, even prince has used one of the beats off of it for one of his songs being played inheavy rotation here in St. Louis.
Also:
TOO SHORT.....Any CD by this guy.... Don't believe me? Download these 3 songs of his:
FREAKY TALES
CUSS WORDS
DOPEFEIND BEAT
Those 3 songs are rap classics.... you will not be dissapointed... and they "WILL" work your subs.
Also:
FREAKY TALES
CUSS WORDS
DOPEFEIND BEAT
If you fall, then get back up........Luck favors the prepared
- purple mx3
wanted to dig up this old thread to see if anyone has any new ones. im also adding one here.
go get the hellsau album. the whole this is absoultly crazy nuts awsome music.
Bochek
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
DO this... PLAY need for speed undergeound.. any version for about 6 hrs... then download the songs.. and get in your car and drive MINUS thye speeding please.
-hec
Yeah infected mushroom sounds pretty good with subs for suure
But my favorite bass song is definitely Hip Hop by Dead Prez.
1993 1.6L SOHC. Mazdaspeed mounts, BP09 ECU, BP VAF, Fidanza miata flywheel, exedy miata pressure plate, centerforce mx3 disc, tokico struts, B&G lowering springs, and some sh***y motomaster tires.
If you really want to make your subs shake your car you need to wait until after they are broke in. Then you need to go to multiple store and search for a cd called Sub-Zone. Flip through those tracks until you get to the resonance frequency test but make sure you change to the next song right when you hear the sound lessen from the maximum otherwise your subs will either pop or blow if they are cheap.
It's all uphill from here
They will only pop or break or lessen in sound if the box is ported and the frequency played is below that of the ports tuning, a sub in a sealed box will not detonate...unless your pumping distortion through it....
Old School song that just plain knocks, posses on broadway..........than again everything knocks in my mx-3......
![Image](http://members.cox.net/hoobahans/avatar.jpg)
got db's? If your windshield ain't breakin you were taken.........
