is it worth the extra 60 bucks to get the megasquirt-II v3 pcb?
If not, then is it worth upgrading from v2.2 pcb to v3 pcb?
Bochek
megasquirt-I vs. megasquirt-II
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
- Custom_V6_Limited_SE
Last time I asked about that I was told that MS II does not have as much support for our cars as MS I and also that v3 was good. Whether that's true or not I do not know.
'93 MX-3 GS SE:My Mods
Bochek
im deffently thinking MS-I v3Custom_V6_Limited_SE wrote:Last time I asked about that I was told that MS II does not have as much support for our cars as MS I and also that v3 was good. Whether that's true or not I do not know.
good price and looks simple enough to build.
Bochek
- XxantwawnxX
thats whati have.Bochek wrote:im deffently thinking MS-I v3Custom_V6_Limited_SE wrote:Last time I asked about that I was told that MS II does not have as much support for our cars as MS I and also that v3 was good. Whether that's true or not I do not know.
Bochek
