Help will be appreciated
I know some might complain i'm posting this problem again... but i'm kinda new to this website... any help will be appreciated ...
My problem is that....
My car jerks and RPM goes down to around 400-500 when in D or R mode... when idle. It only happens when i switch on the A/C
If my air-con is off... no jerks whatsoever even idle or in those D or R mode... no problem....
Funny thing is.. when the engine is cool... even if i switch on the air-con, there wont be any vibration at all...
But when the engine is warmed up... the whole car will definately start vibrating unless i switch off the A/C....
What should i do...
Another problem...
In traffic jams... once i shifted to "D" ... if i stay away from the brakes.. the RPM goes back to 900... but when i hit the brakes, even gently, the vibration starts again.
My mechanic told me i had to change the mounting... but i doubt so that its the mounting, since if i switch off the A/C... the vibration stops and RPM goes back to around 900
i could be wrong though
Again... help will be so much appreciated...
Thanks in advance...
What should i do...
Another problem...
Sounds like the classic alternator problem - Some easy fixes would be to add a ground wire kit and upgrade to a 90 amp GS alternator.
94 Mx-3 Precidia
- atlantamx3
- xtreme velocity
i had the same problem..but i also found out where iw as getin gas..it was bad gas..so i didnt mess with it till i cleaned the tank n got good gas..now it runs better than ever..cheaper gas is not always the best..lol..
Current:
93 F-250 Diesel Coal Roller (For Sale)
06 RX-8 1.3 Rotary AT 6 speed (All looks)
79 Ford Courier 2.3 4cyl 5 speed (lil Pete)
Past:
05 Mazda RX-8 1.3 Rotary MT 6 speed
90 Mazda Miata 1.6L 5 speed 45k miles
94 MX-3 RS DOHC 5 speed 90k miles
Past:
THanks for the replies....
But to be honest... i'm a car dummie....
I just know how to drive.. lol...
So, you were mentioning about the alternator... how does it help in solving my problem ??
So, there are no problems with the mounting right ?
And... since the aircon is the one that is causing the crazy vibration... will it really help by installing the alternator you mentioned ?
- atlantamx3
Just take a length of 4-8 awg wire and connect one end to one of the alternator mounting bolts and the other end to the battery negative - you might see a bit of improvement.
94 Mx-3 Precidia
- Limegreen mx-3
for the a/c u do know it a power robber as soon as u turn it on. car feels slow vib. at idle doesn't acc. very fast.
