Pressure regulators
nos92mx3
Post by nos92mx3 »
cjthor wrote:How bout saying screw the rising rate and just use my afc to adjust? Im runing 320 cc injectors and i wonder if the afc is fighting with the rrfpr for adjustment. THOUGHTS???
What do your maps look like on the safc?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
cjthor
Post by cjthor »
-20s to -30s across the board both high and low settings
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
nos92mx3
Post by nos92mx3 »
What are you doing about your TPS?
93' Rs-t BPT - Sold
cjthor
Post by cjthor »
nos92mx3 wrote:
cjthor wrote:
nos92mx3 wrote: What do your maps look like on the safc?
on the DOHC engines the afc reads a linear signal. I can read 0-100 percent throttle not just on and off.
Jarid Perry
cjthor
Post by cjthor »
Josh wrote:thats what it sounds like to me. i drilled my stock FPR out so its there but flows like a mother fo. i was running a cheepy MSD one and it worked great, now i have this bad a-- comp tech FPR to go with my stand alone.
You used a super afc for a bit right? And im pretty sure you had larger injectors...what were u running for an fpr?
Jarid Perry
nolig2278
Post by nolig2278 »
On my dads 1.6 we added a turbo and RRFPR and injectors from larger sized mazda and larger fuel pump. we tried to tune with a safc but since its a 94 the computer does what it wants regardless so we set safc for 0 and just worked with stock timng and rrfpr and the car boosted to 6 and 7 psi nicely.
I am going to try the safc in my bpt setup to get idle under control.
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
Return to “Forced Induction”
