Bad Head Light Problem Please Help!
Juggalomastaxx
I have a 94 mx-3 and recently I was driving and my headlights just shut off. Highbeams don't even work. But if I flicker them from Highbeam to low beam they'll come on UNTIL I use the turn signal and then they automatically shutoff. Then after doing that so much they won't even work anymore. I've taken it to 3 mazda shops and they don't know anything. All my Fuses are good. What else? please help.
mazdamx3sohc
reaper of souls
if you have drl they could be screwed check the relays and all the wiring from headlight to the interior switch, also check your battery connections if you notice any dimming of your interior lights when your headlights go out you could have a power problem in the car
Reaper
ps could possiable be the lights them self check connections for any corrison and proper watt of lights
Reaper
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.-
Juggalomastaxx
- MechaManZero
Sometimes the switch goes bad too. Lets see a checklist on how all headlights would go out.
Fuse
Wiring
Switch
I don't think both bulbs would burn out with the two fillaments inside each. That would be freaky.
Fuse
Wiring
Switch
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
Juggalomastaxx
reaper of souls
- MechaManZero
are you sure it needs to be removed????
Çlark
Juggalomastaxx
I have a 93 gs parts car and it looks like to me that the switch is well hidden in there. And if you turn the steering wheel it clicks? well that means the gears are right behind it.
Reaper I'm taking your word on the steering wheel and i'll atempt to do it this weekend. I'll let you know how it goes.
Juggalomastaxx
Hi, did you need to replace anything? Or just clean the switch?
I had the similar problem happened yesternite. I drove in the dark. However, if I pull the "stalk" the highbeam will come on but if I let off, no headlights. My parking lights, signals are all working well.
I have taken off the upper column cover and the horn switch...I wouldn't be able to take off the wheel I have no wrench that'll fit to open.
I have still no clue what's going on. I m thinking it's the switch but don't know what's swithc or where's the switch...
Any more details? Thanks
PS: I have checked my headlight FUSE is good.
ken
