ecu location
ecu location
ok guys i need to know the location of the ecu found on the mx-3 SOHC and the location for the computer in a 1991 mercury tracer lts... the car runs really rough and i think swapping the computers will help... all compression in good
- MechaManZero
It is pretty much behind your radio toward the floor. You know those panels in the middle console on the sides behind the radio where your feet go when you're sitting in the car. Pop those out and you might be able to see em.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- Limegreen mx-3
i have ran a 1.8 protege dx/se ecu on the 1.6 sohc. but i would not reccomend. i did run it like that for 6 month no issuse. i would not recommend it was my car i mess it up it was my own flaut.
- MechaManZero
lol
3 plug = auto
2 plug = manual
3 plug = auto
2 plug = manual
Çlark
hey jus use the regular sohc mx3 ecu. thats what im currently using on my mx3. sohc has 3 plugs i belive while the bp engine has 2 plugs.
the way i did my swap was to use the same mx3 harness with same ecu. car works great. been runing for 3months now with no problems.
**~Rayted-M~**
Team **~N.M.E~**
**~CROWN LEGION~** Caloboration
MX-3 Civic head light conversion
http://www.cardomain.com/ride/688645
Team **~N.M.E~**
