higher backpressure = lower max power but generally to a point increased low end torque.
Lower or NO backpressure = higher max power but generally little or NO low end torque
exhaust modification
- mx-3_rider
if you buy the GTX motor then it comes with a AWD tranny...You need to modify the car's body to accept it...mx-3_rider wrote:is it hard 2 make a 3 rwd??/
THEN re-enforce the chassis with Lots of aluminum or steel bracing to make it handle the power in places it wasn't ment to...
As it was said... that usually means 12 or 16 point roll cage.
- mx-3_rider
- mx-3_rider
- mx-3_rider
