So why are Torque Converters a bad idea for a Daily Driver?
I think I know the idea of torque converters
Torque Converters let you hold the brake and hold the gas to higher RPMs then 2000RPMs. Probably something like 3500RPMs
In other words, let you launch like a manual car.
But other than that, why are they a bad idea for daily driving?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
torque converters ARE used in every single automatic car for daily driving.. you mean a HIGH stall converter? i evenb forgot of the name of the thing you are talking about but they are not called torque converters.. torque converter is the round thing that is inside the automatic tranny bolting to the "flex plate" aka automatic flywheel.
-hec
Sorry, I meant high stall convertershgallegos915 wrote:torque converters ARE used in every single automatic car for daily driving.. you mean a HIGH stall converter? i evenb forgot of the name of the thing you are talking about but they are not called torque converters.. torque converter is the round thing that is inside the automatic tranny bolting to the "flex plate" aka automatic flywheel.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- mitmaks
every torque converter has different stall
Because I want to stay smart and not ruin my ATX that was just rebuilt last yearWingleBeast wrote:why dont you just put it into neutral and rev it up then drop it into drive?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
been there done that i did alot of stupid stuff with my old escort and neutral drops are not a atxs friend i ended up punching my overdrive gear through the trany case i could put my fist in the hole that was left so i baby my trannys now i still drive them hard from time to time but not stupid like
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
- cjthor
High stall converters are ok for a daily driver. I am pretty sure they create a bit more heat so make sure to get a good transmimssion cooler. If you havent rebuilt your transmission you might want to do so when you get a new converter.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- Hoodzy
why would u rebuild an atx!!!
1995 Creek Mica Blue GS
- cjthor
some people like autos. with the right mods they are pretty stout..Hoodzy wrote:why would u rebuild an atx!!!
Jarid Perry
Very truecjthor wrote:some people like autos. with the right mods they are pretty stout..Hoodzy wrote:why would u rebuild an atx!!!
Its about time you guys start checking out this thread
http://forums.probetalk.com/showthread.php?t=1701203285
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- mitmaks
727 Torqueflite, one of the best auto transmissions of its era, even to this day it still remains to be on the list of the most dependable transmissions
