As title says i have a OEM Hatch cover for sale. In good shape. Cloth is peeling away at the seam near the back. Is about an inch long, otherwise mint. Email for pics. 35 dollars plus shipping. Headlights will be 50 dollars.
Maybe the haedlights so I will tell you friday when i get my check.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
i pmd you 2 days ago about the headlights and im just wondering if you got them.....
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
