t3/t4 and civic radiator installed
blooprint
Post by blooprint »
take a look. just copy and paste the link.
http://www.clubprotege.com/forum/showthread.php?t=25155
hgallegos915
Post by hgallegos915 »
ive never seen that , awesome :) where did u get fan?
-hec
cjthor
Post by cjthor »
Can anyone post the pics here? I am at work and cant see that site!!! Thanks.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
XxantwawnxX
Post by XxantwawnxX »
Looks nice too! What psi u running and is that a t3/t4 with the 57trim compressor and .63 hot side?
blooprint
Post by blooprint »
yup. its a 57 trim with a .63 hot side. i'm running only 8lbs until i can fix a leaky fuel injector. has lots of top end though!
XxantwawnxX
I was thinking about getting that same turbo for the ZE cause my .48 t3 is to small. : ) its either gonna be that turbo or the 60-1.
blooprint
Post by blooprint »
t3/t4 would be perfect for the ze
Cy
Post by Cy »
WAIT SO DOING THE CIVIC RAD MOD = MIATA BP MANIFOLD FITS NO MODS??????!!!!!
caps lock DEFINETLY intended
atlantamx3
Post by atlantamx3 »
Uhh i dont think so. He is saying he has a N/A BP Intake Manifold.
That Turbo Manifold looks custom. The Miata ones dont come that far away from the head if I remember correctly, not to mention they place the turbo a bit higher in the engine bay.
~Perry
Please visit
http://www.mx3-atlanta.com
blooprint
Post by blooprint »
ok. it is a miata turbo manifold. assuming that you use a standard t3 turbo, it will fit with only one mod. you have to notch the power steering pump bracket. the only reason i had to use a civic radiator in this setup is because the larger t3/t4 doesn't clear the radiator.
Cy
Post by Cy »
blooprint wrote:ok. it is a miata turbo manifold. assuming that you use a standard t3 turbo, it will fit with only one mod. you have to notch the power steering pump bracket. the only reason i had to use a civic radiator in this setup is because the larger t3/t4 doesn't clear the radiator.
your my hero... so what about the 1.6l (which i assume you had first?)
would a b6 miata manifold fit it.. I mean if your not having hood clearance issues then i shouldn't if i drop the front engine mount a 1/2 inch..
MechaManZero
Post by MechaManZero »
Awsome
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
PATDIESEL
Post by PATDIESEL »
Looks good, but I don't see how that crappy little radiator is going to keep things cool with the hot side of the turbo right next to it, and the fact that it is about half the size of the stock one. I would suggest an upgraded radiator and fan and wrap the downpipe. my .02
Looks good though and should give the 4 banger guys some good ideas since the parts used are widely available.
Cy
Post by Cy »
PATDIESEL wrote:Looks good, but I don't see how that crappy little radiator is going to keep things cool with the hot side of the turbo right next to it, and the fact that it is about half the size of the stock one. I would suggest an upgraded radiator and fan and wrap the downpipe. my .02
B18c civics (the Type-R motor) run with turbo setups on 1/2 a rad...
An upgraded doublethick civic rad and a full heatshield would lower your engine temps and your hood's temperature...
Question: Turbo being mounted up isn't the hood going to get hot.. .Like paint bubblingly hot...????
XxantwawnxX
dont think so, us v6 guys have it mounted like pretty close to the hood...i have not had bubbling yet....or fading.
Return to “Forced Induction”
