Hi, I have a problem with my idle but only after I engage electrical loads. So I did some measurements which I find strange but can't tell if are worthy:
1. I measured the voltage between battery (-) and the machine head. Well at idle with no loads i saw 50mV. Then I engaged big scale lights, heated glass, ac... and the voltage was 250mV. Is this supposed to happen or I have problems with grounds and/or alternator?
2. I checked for continuity at the two points we short for retreiving codes, set the AAS etc (in the diagnostic plug) and the buzzer was on, indicating continuity. I think this might be a problem!!!
Thanks.
Experts I need your help
- Typhoonk
1. Take (+) lead on multimeter and touch to (+) positive terminal on battery. Then touch the other lead to the engine's head. You should get battery voltage. If it's different then battery voltage u may have a problem. I really don't know why you got 50mv unless your mutlimeter is a really cheap one and you have some bleed through.
2. I have no idea why you are testing this.
PM for info
PM for info
1. I will try this. But the voltage change may mean something?Typhoonk wrote:1. Take (+) lead on multimeter and touch to (+) positive terminal on battery. Then touch the other lead to the engine's head. You should get battery voltage. If it's different then battery voltage u may have a problem. I really don't know why you got 50mv unless your mutlimeter is a really cheap one and you have some bleed through.
2. I tried this for fun. But I find it strange. This indicates a short circuit! Wtf?
Thanks Typhoonk.
