[FS] 92 MX-3 RS Blaze Red Parts Car plus Misc Parts
Kuromu
Post by Kuromu »
Edited to MOVE!
Okay, I need to get rid of my donor car so I can get my RX-7 in here to start the engine swap on it.
Sooo...
If you need ANYTHING, PM me and see if it is available and make an offer. I have a couple of B6 SOHC engines, some ECUs, RS auto tranny, interior parts, seats, lights, etc. Pretty much the whole car is here except the front bumper, passenger headlight, driver fender, and the MTX stuff that was originally in it.
Anything that is not paid for and out of here by the end of July is going to the scrapyard. I need my RX in here!!!
And sorry, money talks. I have had a lot of people saying they wanted this or that and sometimes the whole thing held for them, but here it is a couple months later, and it is still here.
93 MX3 RS BP 2.0 // 87 RX7 HKS Turbo
Kuromu
Post by Kuromu »
Anyone wanting a project car, this RS can be had for $200. Come pick it up! Needs a new MTX and clutch pedal as I stole it for my ATX to MTX swap, a little body work (rusty in spots), and a little wiring touchup. I stole the plug for the MTX neutral safety switch.
I can provided pictures if needed.
Anyone?
Post by Josh »
you should swap in all your ATX stuff and sell it as a working car
Kuromu
Post by Kuromu »
That is more work than it sounds. Going from ATX to MTX is easy. The opposite is more work than it would seem. Already looked into that. If the parts car does not sell, then I might entertain tracking down another MTX at the junkyard to stick in it. The problem is that MX3s in junkyards are hard to find around here.
Kuromu
Post by Kuromu »
Bump to get it outta here!
ariesdude
Post by ariesdude »
So i guess our deal is off then?
94 Mx-3 Precidia
Kuromu
Post by Kuromu »
That was quick. I was just leaving you a PM right after posting this. The truck I thought I had access to for helping move the car suddenly became unavailable. So if you wanted it, you would have to find a truck. My only option became a non-option this morning.
jrors
Post by jrors »
Kuromu, thanks for working out a great deal with me. You are the man!
If you fall, then get back up........Luck favors the prepared
4gotn
Post by 4gotn »
does it still have an engine...if so what kind
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
Kuromu
Post by Kuromu »
B6 1.6l SOHC, and I have another B6 1.6l SOHC in the garage from my BP swap.
