Alright, to the topic at hand. As the subject states, my car is cutting out on me. It happens under moderate/hard acceleration, and has happened at highway speeds and while accelerating aggressively in first gear. What I mean by "cutting out" is the revs will completely drop off to idle, there will be no throttle response at all, it will struggle quite hard while below 500rpm, and if I don't shut the ignition off it will eventually die altogether. The funny part is, while I'm pulled over, after I give it a few seconds to chill the f--- out, it starts up again, like it would on any other start up, with seemingly no problems. I've been told it could be the fuel pump, which would make sense in theory since it's leaking if filled above half full... so it's always fairly low on fuel, possibly sucking any sludge thats in the bottom of the tank into it. I've also been told it could be the disty (I have a parts car which I could steal it off of, provided the parts car disty is fine) and I've been told the swap the Fuel injection fuse as it might be something as small and stupid as that. I've recently changed the fuel filter in hopes that would do the trick... no dice.
Has anyone else had something like this or similar happen to them? What did you do to fix it? Having my car shut down on the highway whenever it feels like it, as it doesn't happen all the time, is getting to be a royal pain in the a--, and I'd just like to know what's going on with the damn thing
