klde v. klze exhaust manyys
whats the diffrance between the 1.8 klde and the 2.5 klze manny? i hear its just the collector pipeing and if thats true than so what, just replace from the flex pipe back. Im trying to decide if i want to turbo the 1.8 or swapp for my ze witch has my turbo piping alwready on it. any ides ??
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
- PATDIESEL
The stock manifolds ARE different. The ZEs are bent slightly different than the K8s where the second half of it connects. (part between the Y pipe and the manifold) However, if your ZE is turbo plumbed already I don't see any sense in the K8.
- XxantwawnxX
Its not at all.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
- relisys_3200
Awsome. I just orderd my t3/t4 turbo . I hope this all works out but now my question is the intake. I hear that im supposed to gut the intake when you run a turbo.
- XxantwawnxX
i think your refering to taking out or disabling the VRIS plates.
