Headers on a V6 1.8L Stock MX3
INSTYLE101
Just a simple question for anyone, just wondering if anyone makes a header for a stock V6 MX-3, i've looked all over and can't seem to get my hands on one, wondering if anyone could hook me up.
hgallegos915
yeh i got mine off ebay, ss autochrome. pretty much direct bolt on , ha a muffler shop weld the bottom the the cat.
-hec
INSTYLE101
Headers on a V6 1.8L Stock MX3 #2
Is it a big deal to put on a Probe or a MX6 header on an MX3, does it make any kind of difference, if it works all the same its good enough for me but do they actually make a header for a MX3 or due you have to use a header for a different car? And also is there much bending of pipes to make the header fit, and is it easy to install? just a couple questions
hgallegos915
Im mine was a DIRECT fit other than cutting the rear and making it shorter. I have no egr, i used my stock egr plug. Direct fit. No need to bend un less u got egr. And yes its worth it. You will live the extra 7-10 hp
-hec
- mitmaks
where could you find brospeed headers for kl?
INSTYLE101
Juans_93_MX3
- babyblueMX3
it sucks but the one that are proven the yeld the most hp is the one that actually sounds the worst : pacesetter
RIP 400whp ZE-T MX-3
INSTYLE101
Juans_93_MX3
