Cant pick a tire.
Cant pick a tire.
http://www.1010tires.com/tire.asp?tireb ... s+RT%2D615
Falken Azenis RT-615
http://www.1010tires.com/tire.asp?tireb ... Proxes+T1R
Toyo T1R
http://www.1010tires.com/tire.asp?tireb ... %AE+KDW+NT
BFGoodrich g-Force T/A KDW NT
I need them for Auto-X/Weekend Warrior driving. They would also be my main tires for the summer.
Has anyone used either of the 3 listed above and could give me some input on what they know/think? I have looked at the ratings on 1010tires.com but i dont think they're 100% accurate as i believe the ratings are generated off user-reviews. Which would mean whatever tire has the most reviews would have the higher rating. I could be wrong but thats how it looks.
Toyo T1R
Ever notice anyone driving slower than you is an idiot and anyone driving faster than you is a maniac?
01-03 Civic Projector Swap Tutorial
This may help you, car and driver did a performance tire shoot out, the results are interesting.
http://www.caranddriver.com/article.asp ... e_id=10252
If he's looking at Azenis tires, those aren't even the same class. The Azenis are pretty much hardcore Autocross tires. A large number of serious Autocrossers run Azenis tires. I wouldn't buy from 1010 tire, though. EdgeRacing.com is much cheaper, especially for Falken tires.Rick Johnson wrote:This may help you, car and driver did a performance tire shoot out, the results are interesting.
Just wanna check 205/50/15 and 205/55/15 both tires should fit on a 15x6.5 rim right?
http://www.tirerack.com/tires/tires.jsp ... =AVS+ES100
This is the tire I use and this thing sticks like a mofo!!!
1994 Mazda MX-3 KL-ZE
Yes. Of course. Both are the same width. Since you've got a V6, stick with the 205/55/15 if it's for daily use since this will keep your speedo true. If it's a track car, though, you can usually save alot of money getting 205/50/15 since they're a standard Miata size for track use.Neil wrote:Just wanna check 205/50/15 and 205/55/15 both tires should fit on a 15x6.5 rim right?
ive used the g-forces before and well they are an amazing tire.... very grippy and i loved them..... i am seriously thinking of buying a set through work with my discount and might be able to help you out.... pm me and i can see what i can do...
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
That is also the summer tire I use. My second set is just about to be put on. Last set only lasted 2 summers though.Legato626 wrote:http://www.tirerack.com/tires/tires.jsp ... =AVS+ES100
After running Pirellis and Kumhos I have the Toyo T1-S on my Porsche. I chose it over the Yoko ES100. Enjoyed it enough that I went with Toyo winter rubber on the MX-3
My Summer car is a Porsche.
My Winter car is a 1994 Mazda MX-3 GS. 1.8L V6, K&N intake, Pacesetter Short Shift, Corksports SS Clutch line, Suspension Techniques lowered, Toyo Garit HTs for Winter Grip.
I have tried Toyo T1S, crappiest tire ever.
2 months of normal (not spirited) driving, and they were totally worn out.
Also, they were dangerous in wet conditions (almost no grip at all).
Falken FK-451 & ZE-502, was actually better, but worn out too fast, and not the best grip.
Goodyear Eagle F1 - excellent tire, long treadlife (even with spirited driving)
Pirelli P-Zero Nero - the best I`ve ever used, extremely good traction on both dry and wet. I`m running 215/35-18, and I`m on my 3rd season with them now, so they actually last long aswell.
I`m definetely going with these next time aswell.
nope-mx3
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
