Yeah. 12 HP is far fetched. Very far fetched.MOSES wrote:12 HP?.......Holy crap catwoman. If this is true, ill get rid of my power steering.93_mx3_gs wrote:If you aren't running a highly modified motor and drive train, there is no point. You'll gain maybe 8 - 12 HP from freeing it up but it's not worth it for the hassle of slow speeds.
That is a noticable amount of gain.
lakersfan1
- XxantwawnxX
yeah i took out the whole pump plus most of th elines. and the power sterring cooler and resovoir. it has 4 ribs.Mazda_Powered wrote:good job man! so did you eventually remove the powersteering pump and the lines? because im sure the pump and lines have a good weight to them.
also, how many ribs does the belt have? and i think if i got some string and wrapped it around the alternator/waterpump and what not, i should have a close enough size, because i wanna take out my a/c too.
thanks
JACK
Juans_93_MX3
I got a question, how can a U/D pulley for the crank damage the engine?
I looked over the search and didnt find anyone mention damage to the engine.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
OK, i got a quetion.
I removed all my power steering and A/C stuff. Now the problem i was having was i had to leave the power stering pump (which only weight about 2 lbs) connected so the water pump may be run. Since the power steering pump is used as the tensioner. If you removed the powersteering pump how is ur water pump being turned??
- XxantwawnxX
Go back to page one..theres a picture of how i did it. you need a smaller belt...exact size im not sure because i forget.
oh ok, sorry i saw that picture but didn't really understand.
So you have to keep the powersteering tensioner on there? Your better off just leaving the powersteering pump on the car. It can't weight anymore than 2 lbs and then u can at least go to the store and get a normal belt.
Also it doesn't look like u can get any real tension on the belt with the way u posted. Does the belt slip?
- XxantwawnxX
It works perfectly..had it on for years.
- XxantwawnxX
The one that comes with the car lol. You use the same steering rack....just has not power steerign assist with out th epump.
- XxantwawnxX
Yes
Dear god man, the power steering on the 626 (it's the smaller 1990 4cyl version) died again last week. You guys are nuts for driving with no power steering, it's hard as hell. What I used to be able to do with one finger/palm i can't even do with 2 hands, and if you have the wheel cranked and making a turn, you have to slowly bring it back, if you let go, it snaps back to center instantly.
ya, cause you don't need power steering at medium-to-high speeds. I notice no difference when i'm on the highway. Before i could turn the wheel from lock to lock in about a second using only my index finger or just palm the wheel, now it's a 2 hand-effort which is agonising in parking lots. How, i know why people like the feel, cause they can "feel" the road better, which is true, cause your actually more-or-less fighting with the road, cause it wants to move your wheels. It is kinda neat, but i have no problem with feeling the road with power steering, but i especially hate that stuff I can't do. I find I have less control of the car because I have to fight against the road, I can't just tell the car what I want to do, i can't "throw it around" as much.
- XxantwawnxX
i can turn it with one hand while the car is standing still. thats the mx3 though..not sure about biiger cars.
