How to take my dashboard apart?
Sup guys I need some info on how to take my dashboard apart or off in my 93 mx3. Here's what happened, my girlfriend dropped her ring into the heater on my dashboard and it dropped down inside the defrost heater...so I assume to get to the heater I need to take off my dashboard... but what tools do I need and how do I do it??
Hey I love to talk mx3 and car tips on messenger
hgallegos915
its gonna be a bit hard, its been done before use the search feature. I didnt dare to do it its to hard but for a ring :S
-hec
- matrice
um its a long process, start with all the vents, and all the inserts and stuff, pop out the plastic plug in the top by the defrost vent, use a small wrench to unscrew it,,,very hard, get the bolts at the bottow of the center console .. on the side by the doors, make sure you look over things alot to make sure you get all the bolts,,,,drop your steering column, mabey more i cant really remember,,did it a while ago, hope this helps.
