I had a good GTX motor, and a good shell, what else was I supposed to do. She came with the Evo3 kit, but sadly the front was cracked pretty bad when we loaded her on the trailer. I will probably go with a Mazdaspeed front or a PosterT eventually.
MX-3 Rear shot in its new car hole.
From there I began deconstruction of the k8, removing all the accessories and selling all of the little parts that I could to recoup costs of the vehicle.
Finally I junked the tranny and motor (both were blown and not salvageable and began on a plan to get the GTX swapped in there.
I did the necessary research and planning, and decided that with the junkyards that I had at my disposal, I could complete the swap.
I decided to go with an RX-7 FMIC, and mount it on the rad support up front side by side with a half sized civic radaitor. Its a tight fit, but it should make for an interesting hidden setup. The AC has been removed, but the condensor will probably remain to keep the FMIC hidden, as well as AC will probably get an R134a conversion this spring.
Over the months plans have changed and setups evolved. Currently the car still sits, but as a GS with a BPT bolted in there. I sold the GTX turbo for a miata manifold and a T3 so I could really psuh it up there. The car orginally was going to be just a daily driver that had a small amount of boost to get her moving, but as I said plans changed. I'll list her curent mods:
Engine/Performance:
- GTX motor with SS miata manifold flipped
- T3 turbo
- 9lb Fidanza flywheel
- Spec stage 2 Organic clutch
- full SS 2.5 exhaust and IC piping
- FC3S 3.25in thick bar & plate FMIC (hidden in front)
- half sized Racing Civic radiator (2in thick)
- 1.3 Bar Rad cap
Interior/Exterior:
Not too many mods here, as GO comes before SHOW.
- Power windows/door locks installed
- Converted to 95 model passive restraints
- gutted from rear seat backward (will eventually gut from front seats backward)
Suspension/Brakes:
- Brembo blank rotors all around
- SS lines in front and rear (clutch line too)
- 15in lightweight 2000 Miata rims with Hancook 195/55/15's
- ZX2 sturts with Sprint 2in drop springs
- Mazdaspeed top strut tower bars ( front and rear )
As she sits now, I still need to do the following:
- Get the MSnS in to connect it up
- Finish welding the Miata manifold and brace it properly
- weld up custom 2.5in SS downpipe
- weld up exhaust (need to just cut and weld)
- Few MISC things like rad fluid, Alt. belt, etc.
- Bleed the braking system thoroughly
I am sure that there is more that I will find I need to do as, well as more that I will upgrade. As for now, I am pretty much waiting on parts (and the cash to pay for them
Any sugestions/comments are always welcome. As some of you may know I am the resident wh0re off of clubprotege.com and I have a longer, slightly more detailed version of my process as this was written in a few hours, and my thread has been going on for almost a year.
http://www.clubprotege.com/forum/showthread.php?t=16416
