how can i tell a real KLZE from a KLO3 with KLZE head
rudeboymx6
just wondering some different ways of knowing please and thanks
- mx3autozam
lakersfan1
Assuming you're going for boost. Otherwise, I prefer the KL03 heads with the ZE bottom end. Higher compression, and I don't have to worry about the head dropping a valve while I'm bouncing off the fuel cut off.nope-mx3 wrote:I`ve always believed the best combo is the KL03 with ZE heads and cams.
then you get the decent bottom end with better cams, and lower compression.
Handles more boost etc.
nope-mx3
