Turbo
- Black4CylMX3
Turbo
So basically i don't have the money or time to do a full bpt swap in my RS mx3, so i want to turbo the stock 4cyl engine. I've done some searching but haven't found much, so if someone who has done this could tell me what all i need such as what parts and where i could probably find them. Thanks in advance.
if you have a 92-93 RS with the SOHC 1.6, you can get the racingmazda.com turbo kit
- Black4CylMX3
- Black4CylMX3
It's called "transversely"Focal wrote:as compared to ours which can be thought of as mounted latitudal i guess...?
osargeant
Franko, dont be so quick to dismiss a turbo B6 as a viable alternative to the BPT. Plenty of power can be made from the 1.6 DOHC engine especially with a built bottom end and proper tuning.
Infact honestly I have not been impressed with the HP numbers that I have seen from a stock BPT swap in a MX3. Most of the guys then had to modify that setup to produce good HP numbers and 1/4 mile times. I know of MX3s with BPT swaps that are running low 15s for instance.
Your comments are welcome.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
riceracermx3
- jaydog5678
I would say it all boils down to how much $$ you are willing to spend.osargeant wrote:Franko, dont be so quick to dismiss a turbo B6 as a viable alternative to the BPT. Plenty of power can be made from the 1.6 DOHC engine especially with a built bottom end and proper tuning.
The more money you dump into it, the more likely one will be faster than the other.
- Franko
I can dismiss what I want when I want! Stop trying to run my life! I live by my own rules.. no one elses.... Not even my own!osargeant wrote:Franko, dont be so quick to dismiss a turbo B6 as a viable alternative to the BPT. Plenty of power can be made from the 1.6 DOHC engine especially with a built bottom end and proper tuning.
Seriously though, I just like the bpt. I dont think I would have ever gotten a b6t simply because its probally the ugliest engine ive ever seen.. I HATE HATE HATE how the intake manifold is designed so that the charge pipe goes over the valve cover. There is just no way to make it look nice.
I had often thought about turboing the stock engine that was in my car but if I had to choose again, I would definately do the same thing..
My stock bpt was blowing the doors off a turbo focus with a stock engine on 10 psi with a t3. He tried turning up the boost to 15 and the tuning ability just wasent there causing one of the connecting rods to get tired and decide to make an exit through the side of the block.
Im intrested to see how things are going to be with this new setup Ive gone for.
why not get a b6t block with a b6de head? lookes better then the ugly b6t i admit and it flows air alot better also....
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
