well i went to the local drag strip the other day with my BP mx3 expecting to run high to mid 15's or better, but instead this is how i do..
1st run
R/T .726
60ft 2.402
1/8et 10.830
1/8mph 64.49
1/4et 16.891
1/4mph 79.35
2nd run
R/T .946
60ft 2.257
1/8et 10.619
1/8mph 63.98
1/4et 16.695
1/4mph 80.93
my track times.
osargeant
Something is definitely wrong there, those are times I used to do with my 1.6DOHC when it was NA, either the BP engine needs looking at, clutch may be slipping, tranny issues or you need to practice your launching and shifting.
A BP powered MX3 should be running high 15s easily. Certainly at least a flat 16 for sure.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
LooseChangeRacing
yeah and work on your reaction so you can always keep it around .7 or so, thats good for amature, your 60's are too long and it does seem like your got some compression issues or something cause even with those 60's I would of thought you would have gotten closer to a flat 16
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
mitsudriver
sounds like your clutch to me94_MX-3 wrote:nah the clutch isnt slipping that bad, but when i shift on the track thats when it slips. it has that sound of RPM's droping then raising.
