how much hp/boost approx can i run with millenniaS injectors
rudeboymx6
just wondering if anyone can tell me how much horsepower i can get out of the milenia S injectors in my v6 2.5l engine.i am going to run megasquirt just need to know if the injectors will b good for 250-whp.
- XxantwawnxX
as far as i know they will def be good to 250 HP(and more)...i think the nomral ZE injectors are good to 250 hp. But i can be wrong alot.
- jschrauwen
- XxantwawnxX
Gonna be a beast!
- babyblueMX3
ya kj injectors can give you fuel for around 7-8psi maybe 9.
but you can't really tell by psi, it's really by hp. I'd say up to around 275hp without maxing them out (recommended). Probably 300hp maxed out (not recommended)
RIP 400whp ZE-T MX-3
