Juans_93_MX3 I bet you did not expect to open a can of worms when you posted this thread. I hope you enjoyed the discussion and found it helpful as well.
XxantwawnxX a few degrees off should be OK. For about a year or more and up to last week I was driving around with only 7° of base timing untill I figured out the problem which was attributed to an AutoZone replacement disty (see my http://www.mx-3.com/phpbb2/viewtopic.ph ... 817#320817 thread for more info). But the car still felt OK under regular driving conditions. I like to have my car sharply tuned You know what I mean And with todays gas prices anything to help save a little more fuel is a good thing.
Well...thanks again XxantwawnxX it's been a good discussion. Good luck with your certification. Don't forget to check that base timing
If I removed the distributer, would I need to time it or
- FlyVFR
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- XxantwawnxX
Buahah yea i will. Yea im working on TC project for my ze...its getting there, id like to be as tuned as possible also (at least when im TCed): ) Thanx again
