Clicking From Passenger Side Rear Wheel
I have a clicking noise coming from my passenger side rear wheel. The click seems to rise and fall with speed. Is it the bearing that needs to be replaced? How long should this take to fix, and are any special tools needed?
Matt Domenick
1993 GS-ZE
1993 GS-ZE
- JWMX3
The rear bearings are replaced with a whole new hub assembly, while the fronts u reuse the hub and have the bearing pressed out
normally when a bearing is gone its more of a whuuuurrring noise, not clicking
what about when you go over bumps? is there any pronounced noises ?
onderground_mx3
- PATDIESEL
REAR is not an axle.
I'd also check that the brake clips aren't hitting the wheel. I had that happen to me once where one broke and was flapping like a playing card in a bicycle wheel.
hgallegos915
hmm i had that problem..well have...its my rear rotors..to thin nd the brake is floating not touching the dish so it moves around..thats whats wrong in mine..im hoping urs is the same
-hec
onderground_mx3
